1 - 17 of 17 Posts
Hello All,
First time here. I just picked up a early 67 MF10. It's complete but needs seat and hasn't run in a very long time. So I'm restoring it as a project for the winter. My question is that it doesn't have a key switch. Only a flip switch and starter push button. It looks original by the wiring and holes. Did it actually come this way? I figure I did alright for $35. Thanks
:wave: Welcome to the forum! Give the folks a bit to see this! I'm sure they will answer your question.
Welcome to GTtalk,You got a great deal on that Massey.Theres only one problem.There aren't any pictures of it.So lets see it.If it is a 67 then it would have a starter generator on it,and also points.I believe that one used a 3 prong key switch.I'll have to double check mine.They may still be avail through agco.As MH81 stated above you want to be positive you get the correct switch.
Ryan's 66 has a key switch like all the other ones. It's a Massey shaped key, so I'm pretty sure it's original.
I would be stunned if the switch was still available from MF, but the one for a 60's-70's Sears suburban with Tecumseh engine will work in its place.
Just make sure it is marked M instead of I on the terminal.
Bush Hog Addict
Welcome to the forum! Yes....$35 was a great deal. :thumbs: You are in good hands here. We have several MF experts on the site and they know their stuff for sure!
Yes mine is like the picture MH81 posted. I was able to get another spare key for mine from John Deere, however I doubt that the Deere ignition switch the key fits in would be correct. In the John Deere world that key fits an old 510 tractor ( if I remember correctly)
I found a used one for sale. It looks like a three terminal and then a fourth one look like a ground. Is this correct?
Just be absolutely sure the wire that connects to the ignition system ( CDI) never has power on it BEFORE you connect it to the CDI.
When the key is off, that terminal should short to ground, not have power when on. BIG Difference.
For some odd reason, I have run into this several times. I've seen those ignition switches on several JD's and always wondered.
1 - 17 of 17 Posts
