1 - 3 of 3 Posts
I have a MF12 it will not get any spark?Checked all that i know swapped parts of my MF10. Haven't got got to the stator yet dont know what to check on it nearest i can tell all parts i swapped didnt help.Something easy????If stator where do i get one any help would be nice.Thank you Massey Friends.:wallbanging::wallbanging:
Hangin' with the cool kids
Ontario, Canada
Is it a solid state ignition?
My MF10 the other day was cranking slowly, guess the battery was a bit low........it wouldnt start, like it had no spark.....As soon as I boosted it, it fired right up.....Its like the SSI needs a certain voltage to fire.....Once I charged the battery up, its been good....Not saying thats your problem, just thought it was worth menuioning
hi everyone in Massey land i have an MF12 was running great i was using it to rack my pasture one day here in California it is kinda hot but it was evening, anyway it started to make like a popping noise so shut her down but when i went out later to bring it in it would not start. So i checked the gas no gas so put some in still no start well as much as i hate to say this it did not come with a key so i was using a screw driver now i have a new switch and key but i want to make sure i put the right wire to the right place on the switch i did down load the wiring diagram that you posted thanks. even though i have a new switch it may not start since it would not before i will be back to ask some questions thanks
1 - 3 of 3 Posts
