1 - 3 of 3 Posts
I have a mf12 hydro with solid state ignition. I need a new ignition switch. I've read several posts on here about it but haven't found any definite answers or part numbers. Mine has 4 posts on the back of the switch. Can someone here give me a part number for a replacement switch? Thanks
I do not have a part number, but do know that it needs to be a "ground short to kill" not "power to coil" style. If you get a switch that applies power, it will damage the SSI/CDI unit.
Now days, they are denoted with a "M" on the terminal that goes to the wiring.
You may try agcopartsbooks.com also. Mi can't from the iPad, or I would look it up.
1 - 3 of 3 Posts
