1 - 13 of 13 Posts
Discussion Starter · #3 ·
Both have almost the same flexibility , as you can see in the picture . My concern is that the brake drum diameter + brake band thickness is bigger than the interior diameter of the brake shoe , if you see what I mean .
I measured mine from a 1968 MF12 H & I'm around 3.6 - 3.9 so I would go with the 4 as well. According to mine I have a lot of room for adjustment to keep the band from being too tight on the brake drum. Hope this helps.
  • Like
Reactions: cheluIS
Discussion Starter · #5 ·
Finally I changed the brake band .
The brake band was worn-out unevenly .
Motor vehicle Wood Gas Auto part Machine
With a chisel remove the old brake band (or what's left of it) .
Wood Motor vehicle Gas Metal Automotive wheel system Helmet Wood Gas Automotive tire Personal protective equipment
Remove the remains with a mini drill or by hand with sandpaper .
Automotive tire Motor vehicle Wood Gas Automotive wheel system
Don't forget the goggles and mask . The dust from the old band I'm pretty sure has asbestos , is very toxic .Sorry for the picture .Hope you don't have a nightmare
Window Gas Artisan Engineering Machine
Roughen the surface for bond strenght .Some lines with the tip of the chisel will do the work.
Tire Automotive tire Wheel Tread Wood
Cut the necessary lenght of brake band .
Automotive tire Bicycle part Cart Tool Rim
Put some masking tape over the brake drum to avoid bonding the band with the drum in case of adhesive leakage .
Gas Machine Circle Automotive wheel system Wood .
Prepare for operation . After mixing the 2 components you have aprox. 6 min. to put the brake band and the whole ensemble in place . Don't detach the brake rod . You need to put the whole ensemble in place to draw together the band and the shoe till glued .
Motor vehicle Tire Gas Bicycle accessory Auto part
Put the brake back in position and put the varidrive lever in PARK .
Automotive tire Automotive exhaust Motor vehicle Bumper Alloy wheel
Leave for 24 hours for bonding .
Let's hope that will last . I'll keep you informed after few runs (hope the tractor will stop with it's brakes not in a fence or something :hitting_self_roller: )
Keep in touch .
Looks great...nice tutorial too.
Thanks for walking us through that.
Handy info to have around.
Do you use any solvent to clean the metal, before
applying the adhesive?
With the way the variable clutch works, just slowly depressing the clutch will slow the tractor down quite a bit, even if your brakes aren't working quite right.
Anybody knows the thickness of the brake band ? I found 2 types : 30 x 4 mm (1.18 x 0.157 inch) and 30 x 3 mm (1.18 x 0.118 inch) . I want to replace the band at the brake shoe and I don't know what thickness to use . I'm gonna to glue the band with Loctite 3430 - http://www.youtube.c...h?v=5r0PrZO83xM
Where did you find the band material at.I think it would be nice to have it around for repairs.
1 - 13 of 13 Posts
