1 - 8 of 8 Posts
I want to make a little maintenance to my MF12G.I want to lubricate the variable speed pulley but I don't know how to remove it .
And second: the variable speed pulley have a play from left to right . The pulley has to be tight to the axel ?
I don't know if I described the problems very well so I'm posting 2 pictures .
Any sugestions ?
Thank you .
Electric Tractors
The screw that holds on the double pulley set is LEFT HAND THREAD
Discussion Starter · #5 ·
I did it ! I unscrew the left hand screw from the pulley.But I have the impresion that something is missing.I have a little gap (space) between the pulley and the washer.Between theese should be some kind of bearings ? The washer has some grooves . Please take a look at the photos and give an opinion . When I screw the washer is not tight to the pulley .
Thank you very much .
Electric Tractors
Mine has a little bit of play in it when it's together.
About 1/8" back and forth, the whole assembly, doesn't appear to be a problem.
On my screw there is a washer like yours, has groves in it and a toothed washer.
1 - 8 of 8 Posts
