1 - 20 of 49 Posts
About a month and a half ago, I picked up this rig. Had no motor.
Tire Wheel Vehicle Car Automotive tire Motor vehicle Hood Automotive lighting Vehicle Automotive tire
Since then, I've tinkered on it, an hour here and there. It had been repowered.
The engine mounting plate was wrong, and the drive shaft had been shortened.
I also had to relocate the oil drain plug off the bottom of the oil sump on the 16hp
Kohler K341 I am putting in.
Tire Wheel Automotive tire Tread Motor vehicle Wood Automotive lighting Flooring Floor Tints and shades
Brown Wood Chair Hardwood Flooring Wood Motor vehicle Floor Flooring Gas
Motor vehicle Automotive fuel system Wood Automotive tire Automotive exterior Automotive tire Motor vehicle Bumper Wood Automotive design
I got it fired up last night, but not getting any action out of the Sundstrand
transaxle. It's a 90-1155 LH. I notice that it had an old MF filter, so I changed that, making
sure to fill the canister with ATF. Filled the rear end with ATF. (it was down 2 quarts) I had found
earlier, that the oil level plug was loose, and the upper end of the suction line was also leaking.
I've poured about 3/4 of a quart of ATF into the pump via the aux return port, and raised the rear
of the tractor, so the suction line port on the reservoir was higher than the filter.
I'm not getting any action on the lift cylinder either.
I guess my first question is, should the LH on the charge pump be on top. It is possible
that was changed with previous repower.
Pretty sure LF is correct as you determine rotation by looking at the shaft end, but I'll go check my old MF14 pump that has never been disturbed to be sure.
I hope that you're driving the hydro from the flywheel. Otherwise, the charge pump will be upside down and so will the hydro motor section.
Discussion Starter · #5 ·
Yes, I'm driving off the flywheel. Same as original, except with the K341 instead of K321.
I'm rounding up a pressure gauge, to get a reading before I tear the rear end out. I did have the
relief valve out. No shims there that I found, and it all looked Ok. (from my inexperienced eyes).
I've never had to tear into one of these rear ends, so I'm kinda looking forward to it.
Will are there any bypass /check valves on that model. If it has a L -N_H transmission then it probably doesn't have the bypass feature. They have a habit of sticking in the bypass position.
Discussion Starter · #8 ·
Brian, there is no bypass feature on this tranny, as there is on the one in the MF12H. Only the neutral position, and a big sticker
that says "Do Not Tow"
First are you using tranny fluid, is the 2-speed shifting arm in low or high, could it be air locked, do you need to change filter. Just a thought.
Yes, I've changed the filter and filled up with ATF. I tried in both Hi and Low range, several times.
This evening I put a pressure gauge on the charge pump. 000000.00000 pressure, so I took the cab, and rear fender
off, to get ready to remove the tranny. Then mother said I had to come home. Glad I did. Fresh perch, salad, and little
potatoes. Yum.
Should be able to get at it earlier tomorrow.
Did you look inside the charge pump? If it's the charge pump, it's simple as sin to fix or replace. Pull the driveshaft, then the 4 charge pump bolts & pull the charge housing off. All will be easy to see if there's something wrong there & may not need to pull any of the tranny.
Discussion Starter · #10 ·
Thanks Dan, yes it would be easier to pull the drive shaft. That thought had crossed my mind, but
I was worried that I couldn't really explore the pump properly, with it mounted in the frame. But I will
give that a shot.
give that a shot.
You'll have the pump in hand to explore to your hearts content once you take the bolts out.There's not much to see on the hydro side once the pump has been removed. It sits on a flat machined surface with 2 quarter moon slots for the fluid to enter and leave.
The pin is a needle bearing 1/8" diameter and about 7/8" long. It's a slip fit in a cross drilled hole in the input shaft. Orient the shaft so the hole is horizontal when you put it back together.
Discussion Starter · #15 ·
I got the charge pump off this aft, and immediately saw that the drive pin was broke in 3 pcs.
Upon closer examination, I also discovered that the outter gear of the Gerotor is badly worn
on the outer face, and the diameter.
Tableware Body jewelry Tool Jewellery Wood
Tire Automotive tire Wheel Tread Motor vehicle
Are these parts still available anywhere?
Discussion Starter · #17 ·
Discussion Starter · #18 ·
Time for an update.
After discovering the gerator was worn badly, I took a look at the end cap of
the charge pump. Badly worn too.
The gerator set from Paton was $85, and would take 2 weeks + shipping, tax
and brokerage fees. Probably end up at about $175, and still no end cap.
I called the Cdn Danfoss dealer. $349 and 6 weeks for the cap, and gerator set.
Considering that all that smeared metal, went to the motor, I just couldn't spend
that money. Doug (DH1) had a spare complete tranny on the shelf. We struck a deal
and he brought it up this past Sat. when he came up for the trail ride/meet and greet.
This aft, I installed it, and now I have a moving MF14. Thanks Doug.
Time for an update.
Glad your 14 is up and running again!
Electric Tractors
Good stuff glad to here it still works, hopefully it lasts and does the job it's needed to do.
1 - 20 of 49 Posts
