1 - 4 of 4 Posts
Hi again.all...does anyone know if a max power 9623 Ignition switch will match up with my Massey 16...mine has had a gas shut off solenoid installed but it seems to be the original ignition...I thought it was the implement switch that was bad but its the start side of the ignition. I can start it with a momentary switch but a new ig.switch would be nice...thanks Don.
Not sure about the part number, but my MF 14 ignition switch has four positions. Off / run and accessory / run / start .
Noel
The original switch is available from the Massey dealer
They are around 60 CAD
They have 4 positons, off, run with lights, run without lights and start
Wire diagram is in the operators manual for MF 14 and 16
sounds like that switch does not have the light position
Has your tractor been repowered
Pictures would be nice
The gas shut off solenoid is not factory for a Massey MF 16
1 - 4 of 4 Posts
