1 - 13 of 13 Posts
That looks like the kind that are on snowmobiles. Kirk something or other is a on-line snowmobile parts company. That might work.
Good point Daniel.
The vented Caps have a very small hole in the clear plastic. That could be done with this one but then you are back to what it came with and the chance of water getting into the tank. I would like to find a different way of venting to prevent water infiltration. These work well. Vent cap.jpg Small down to 1/4" thread screwed into top of tank.
I always put a plastic bag flat on top of the OEM cap and lower the hood on top of the bag when they need to stand out side.
  • Like
Reactions: IamSherwood
The John Deere 212 thru 216 are the same thread. Took my cap to Fred's & checked on a 214. Not sure how deep the 50 Massey series is, so measure the depth to be sure, but I think these 9" caps would be close enough. The 55 series tanks are about 12" to the top of the filler neck.
Premium Member
olcowhand said:
The John Deere 212 thru 216 are the same thread. Took my cap to Fred's & checked on a 214. The 55 series tanks are about 12" to the top of the filler neck.
Thats good to know that they will fit.I've been making a new site glass [plastic] for mine every year and expoxying it on.It seems to need to be replaced once a year due to the plastic cracking and yellowing.Now I can go to JD 25 miles from here with a part # in hand and order one ,probably this spring.
Discussion Starter · #10 ·
So, Kelch is the name for that thread. Looks alot like the thread on portable outboard motor tanks. I'll try that too.
Thanks guys.
Thanks guys.
Oh yes, "Kelch" is the thread type. They come in different sizes though. Most GT's are 2 1/4", some are 2 1/2", with ATV & other sport stuff up to 3".
I thought it was something you only did in the company of other men! :bigrofl::bigrofl:
1 - 13 of 13 Posts
