1 - 20 of 28 Posts
How come no snow on the trees???
How come no snow on the ground under the trees? That second pic bothers me. Not that I doubt the snow level, or the fact the tractors/implements are covered, just something about that pic.
  • Like
Reactions: IamSherwood
Discussion Starter · #7 ·
Doug, I noticed something about the picture too.
Handwriting Plant Rectangle Font Tree
I think there is more snow job than snow here...
Well get shoveling man!... Just kidding, this isn't life or death and honestly not even necessary... Just wanting to.
I'm sure someone has one that isn't buried.
I started today, but got side tracked.
Plant Tree Snow Woody plant Art
Electric Tractors
After the last snow removal, Ryan's belt had come off the 620 a couple of times. I'd like to make him a belt guide to reduce the chance of it happening more.
To do this, I need dimensions on numbers 9 & 10
Thanks in advance.
I think that the rounded sheet metal piece is about the same dia. as the engine pulley and the 2 bolts that hold it in place screw into the block to stop the belt from coming off when it's not engaged. plate is held out just far enough to clear the pulley.
Wheel Tire Tractor Vehicle Automotive tire
I am trying to measure and draw it, but I keep messing up :wallbanging: LOL. Getting a coffee then I'll go at it again :D
I finally got the measurements and everything worked out, but my printer/scanner is acting up so I had to take a photo with my phone.
Hopefully you can see this ok, if not maybe I'll be able to get the printer working soon?!!
Rectangle Font Handwriting Parallel Pattern Rectangle Handwriting Font Parallel Pattern
Rectangle Font Parallel Pattern Symmetry Handwriting Rectangle Font Parallel Pattern
Wood Handwriting Font Cross Nut
I am hoping one of these is visible for you! Maybe Kenny feels like a drawing project?? :D :poke:
Any questions just ask.
I have a feeling someone welded it on to help keep the belt in place??? It is the only one I have, but it doesn't look original?
1 - 20 of 28 Posts
