1 - 20 of 52 Posts
Electric Tractors
I have 2 of these both 23" wide and complete.
First one serial# 1518 003236 (early) Has the tractor+plow on logo, has a square drive input shaft, has the Hydro extension sleeve on it (optional).
Second one serial# 1518 008167 (later) Has plain logo, has splined shaft input, does not have the sleeve extension on it.
Both tillers have splined end drive shaft at the front gear box.
In the AGCO parts books it shows the extension sleeve for use with Hydro tractors, Vari drive don't use it, tractors have different wheel base's.
Sticker on newer tiller says mount in center holes on tractor.
Nice units. I have a later one on my mf10. I placed an add on craigslist and have been doing a little side work tilling with it. I've made a little $$, met some nice people and really enjoy doing it. I didn't know you needed an extention to use it on a hydro, it's good to know because I have a mf12h also.
Electric Tractors
Discussion Starter · #3 ·
You don't really need the extention, I've had both these tillers as you see them on my Hydro, no problems. I guess they put it on to make sure it fits???
Premium Member
Nice tillers, I want one really bad.
We had a nice spring day today so I was using my tiller this afternoon. I have one with the extension mounted on an MF-10. I like the gearing on the 10 better than on my 12 Hydro. I run the tiller with the tractor in the lockout gear and the variable speed down at 1. The only drawbacks with the 650 are that it is a bear to lift, even with the 3 assist springs. I end up flexing the lift rod to pull it out of the soil also if you're breaking up a weedy plot or sod, clods get stuck behind the bracket and I end up losing traction. I've seen other '60 vintage tillers on Deere's and AC's they seem to mount more from the top like a 3 point would rather than from the rear like the MF650. I think those designs probably run a little better in sod, but I'm not sure they are any easier to lift.
I have a second 650 without the extension, (or the gear box) which I don't use anymore. I used to think that there wouldn't be enough HP to run the wider tiller, but other than the lifting weight I don't notice any difference. The MF-10 has power to spare with the wider unit.
I'd like to know if anyone uses theirs on a Massey with ag tires? If so have you noticed any benefit? Thanks.
Premium Member
Todd, aka tweidman has a 12 hydro and he has ags on it and I am pretty sure he used it with his tiller. Maybe he will chime in here then.
Electric Tractors
Discussion Starter · #7 ·
I agree with NYMalloys tiller works better on a Vari Drive than the Hydros, much easier to hold a slow steady speed on a Vari Drive tractor.
Premium Member
I would still like to get a 12 hydro but to be honest I love using my 12G. I just need a tiller to be able to take your side of the fence on this LOL.
  • Like
Reactions: NYMalloys
I have never used my 12 with turfs, so... I don't know how it compares.
I also have an electric lift, so the tiller lifts with the push of a button...lol.
Electric Tractors
Discussion Starter · #10 ·
I don't thing AG tires would make a difference, my turf tires with wheel weights do fine, no traction problems at all.
I'm sure if you were pulling a plow or cultivator it would be a different story.
Premium Member
NYMalloys,
You have quite a collection of Masseys. We would love to see pictures of them.
Yes I have a few more than my wife is aware of. I started buying them a while ago. It seemed that years ago the used Cub Cadets and John Deeres were priced for the collectors, but the Massey's weren't. They were priced as used (and usable) old tractors (and the AMFs were just being given away). I bought some of them for less than $30 and would buy them either for parts or just to mount a specific implement. Now even the Masseys seem to fetch a bit of a premium. It may seem like a luxury, but I have enough that I never have to wrestle removing the tiller from a 10 or the snow thrower from a 1010, I just park them in the barn when I've finished for the season. I can take some pictures, but I'll warn you in advance that all still see lots of use and aren't show tractors. Though shows may be in the future if I find a sand blaster at a good price.
Premium Member
Where are you located at Doug?
Premium Member
Your not too terribly far from me. I would say about 4 -5 hours.
doug fulwell said:
i have model 650 tiller for sale. i got it from someone who thought it was a 550 to fit on my
MF14
Go get it George, you know you want to.
Premium Member
If I knew for sure what was going on with our living situation I would.
Electric Tractors
Discussion Starter · #19 ·
George if you buy it make sure it has gear box, drive shaft, spring bracket and springs, other wise it's not really usable.
Premium Member
I can't buy, got too much stuff going on right now. I would love to though but will have to wait a couple months.
1 - 20 of 52 Posts
