1 - 3 of 3 Posts
Been searching for the correct blades for my MF7's deck and I haven't found an exact fit blade yet. Everyone I've found has to be modified one way or the other. Usually they are long enough but only have the center hole. So I have to get the other two positioning holes milled out.
Any ideas or links for an exact fit blade?
Also, there are two positioning pins used to hold the blade from spinning on the shaft. Does anyone see any issues in using roll pins instead of the softer pins that came in the spindle?
Good news is the newest mf7's deck driveshafy and spindles came right apart last night. Splines all look good and intact. Just doing a general cleaning....but the gear boxes do require new seals at the bottom. Otherwise all is good.
I was able to source blades for that mower at my local Massey dealer. Can't really help about the pins, I'm going to see if you get any other replies because I need some pins also.
Discussion Starter · #3 ·
Here's an update.
Took the deck off the MF-7 I picked up the other night and all bearings look to be good and tight. The output shaft seals are pretty rotted so I set out to find them from the local bearing house.
For your reference:
Massey # National Oil Seal # Description
833911M1 471730 SEAL- OUTPUT SHAFT
833912M1 471267 SEAL- INPUT SHAFT
Got two of the 471730 (output shaft seals) on order. Takes a day. Total cost with the governor's share was only $17.52 ($8.72 each) for the National brand.
I've yet to find out much information on crossing over the bearings but once I get the gear boxes cleaned up, maybe I can find a part number.
  • Tim
1 - 3 of 3 Posts
