1 - 11 of 11 Posts
Just picked up a 70's vintage MF8 and I can't seem to get the brake to operate correctly. The left side pedal pops it into the neutral position when depressed but it doesn't slow down prior to it going into neutral. The operators manual dosen't help me out. Can someone explain how the braking system operates and how to adjust it. Thanks in advance.
Electric Tractors
I am pretty sure that when you step on the pedal the hydro lever goes to stop or neutral and if you push all the way down the brake apply's via cable, has a disc and pad. I'll check mine tomorrow.
Discussion Starter · #4 ·
Thanks for the info, you indicated there was some sort of cable to the brake. The only cable I see is for the parking brake. Any pics of the set up would be appreciated.
Premium Member
I have an MF8 hydro also but have never torn it down to see how it was setup. I have never used the pedal for a brake, always just used the lever. Which reminds me I need to do some checking on my lever because it is tough to move out of neutral. Maybe I will look at it tonight and I can get some pics of the brake setup.
not sure how much the MF8 is similar to the MF14, but my 14 has an adjustable rod for the brake under the seat. I'll check tonight and let you know.
Discussion Starter · #7 ·
That's how I'using it just operating the forward/reverse lever. I just would like to slow it down with a brake as I have a slope on the property. My MF 10 is an entirely different set up with the variable speed thing. I having some problems with that one also with the clutch/brake set up. It appears the front drive belt is a little tight and when the clutch pedal is depressed it does not disengage totally. I'm still trouble shooting that one but I'm thinking the guy who gave me the tractor replaced the Tecumseh HM10 with a Kohler K181 from a John Deere and the centerlines of the crankshafts might be different. I'm trying to track down the specs for both before I start any major surgery to try to solve the problem. I kinda remember seeing it somewhere that the Kohler's crankshaft was centered a bit forward compared to the Tecumseh.
Premium Member
I didn't get a chance to look at my MF8 yet. Possibly tonight. I want to say that there is not a regular brake on the MF7/8 hydros. There is a parking brake. You can use the hydro lever to control everything as well as use it to choose what speed and slow down going down a hill.
Regarding the MF10, have you gone through the vari drive adjustment procedure outlined in the manual?
Discussion Starter · #9 ·
I followed the owners manual to a "T" with no luck on the MF10. But the good news is I just picked up another 10 off of craiglist and it looks like all I have to do is figure why it has no spark. Everything else seems OK. Between the two 10's I should be able to make one good one.
With respect to the MF8, the parking brake is the only thing with the cable, the pedal only seems to operate to neutral then it brakes abruptly once in neutral. There is no braking effect up to the time it goes into neutral,
Premium Member
I am almost 100% positive there is no brake other then the parking brake due to the hydro control can take care of all of that when in operation.
Electric Tractors
I checked the AGCO parts books and there is no real brake, only a parking brake, all the braking is done by the Hydro control and when you step on the brake pedal all it does is move the Hydro control to neutral.
Can't verify this on my tractor as the control cable is seized, something else to put on the to do list.
1 - 11 of 11 Posts
