1 - 20 of 45 Posts
I got this MF8H off member DH1 in Dec. 2011.
Serial # 1590507128, makes it a 1974 I believe.
Engine is a Tecumseh HM80-155019A 4267R
Wheel Tire Vehicle Automotive tire Agricultural machinery
I had it in the shop in May/Jun this year, and fixed up
most of the mechanical issues, which weren't many.
Primarily, the carb, and the seized hydra control cable.
A few weeks ago, I brought it back into the shop, and tore
it down in between working on the MF8E and dealing with
mother nature. Getting the steering wheel off, took 3 days
with the puller, and PB Blaster.
Wheel Tire Automotive tire Tread Motor vehicle Tire Wheel Bicycle tire Bicycle wheel Crankset
I only tore it down far enough, so I could get at everything for scraping, sanding,
priming and painting access. Sure is a lot of parts on these guys. I think more
than any other in this series of MF.
Wood Houseplant Gas Engineering Machine Engineering Wood Machine Gas Hardwood
Automotive tire Motor vehicle Automotive design Shelf Engineering
Of the 20 or so I've had my hands on, this is the first one I've had, where the
dash is intact. No cracks, or broke off mounting tabs. Exciting. :dancingbanana:
I've got all the rest of the parts degreased, decals removed, and any repairs
that needed doing, finished. Now I'm waiting for this "Polar Vortex" to settle
down a bit, so I can sand blast and carry on.
Table Automotive tire Motor vehicle Bumper Flooring
You've got a good start on it already Will. Is the steering wheel damaged, it appears to be the same as used on the C-series WH. tractors. I have one here at home if you need me to check measurements.
  • Like
Reactions: IamSherwood
Discussion Starter · #5 ·
Brian, the wheel came off, without me damaging it, but I'd like to replace it.
If you look, in the pic, below the lower spoke, you can see the vinyl appears
to have been chewed by a mouse, or picked at by a nervous grounds keeper.
Thanks for the tip on the WH wheel. I'll look into that.
Discussion Starter · #9 ·
Wow Will, your already working on another one.You're making us all look bad. :D
Sorry, but if I don't, Mrs. will find stuff for me to do. Paperwork, and yucky stuff like that.
I might have to start another one, if I can't get outside to sandblast this stuff soon.
That's what I was asking about. I will take a picture of my wheel with a tape measure across it.
  • Like
Discussion Starter · #13 ·
DSCF5633.JPGThis is my MF8. Been in the family since new. I need to do what you are doing but i have too much in front of it. I havent quite gotten all the carb issues worked out, but it does cut well.Nice to see another MF8 being restored!
That looks to be in real nice shape. I did some cutting with it in Sept. It is nice
to cut with.
Traill95
Nice looking, :thumbs: I need to get back out to the shop and get my mh8 running. still having problems with the motor.
I have always liked the looks of Masseys,the front end are just to cool.Can't wait to see yours when it's done.
Got a massey 7 (I think it said 7) Not hydro year unknown.I got it up north by the camper,used it for years mowing until rod went through the block.
Think I'am gonna drag it home this spring and bring her back to life.
Discussion Starter · #19 ·
I managed to get something done on this one, in between all the
winter weather activities.
The rims got wire wheeled, sanded, primed, and painted.
Front axle and tie rods too.
Today was nice out, so I got everything sand
blasted, primed, and some painted.
Machine tool Gas Engineering Toolroom Machine Furniture Automotive tire Table Road surface Asphalt
Wall Wood Gas Space Flooring
1 - 20 of 45 Posts
