1 - 5 of 5 Posts
Hello all!
I have a couple MF10s and a 12G along with a bunch of implements. I am in the process of cleaning everything up and have a couple of pieces for a MF630 dozer blade. I am considering fabricating a bar that runs under the tractor. To this end I would like to get as much information on mounting points and installation as possible. I have a parts book for the MF10 which lists the parts.
Does anyone have this implement and/or information they could pass on.
Thanks!
Ron Paul
bar??
the rear of the blade bolts right into the trailer hitch. the lift rod fits right into the wide slot on the middle of the blade. the front of the blade is suspended with a spring. the spring is held with a u shaped bracket that mounts to the front bumper
tractor tinkerer 2 :welcometogttalk:glad to have you here.
By bar perhaps I should have said angling bar assembly.
Is the bar supported only by by the push tube assembly?
I need to made this piece as well but it seems straight forward.
Thanks.
I added a file to the Massey implement section showing the mounting points and hardware information etc.
1 - 5 of 5 Posts
