1 - 7 of 7 Posts
I was in the process of taking off the mower deck,,,cleaning ,,and putting up for the winter. I wire brushed the under side and primed it up,,and then remembered that ,,,Sometimes the center blade didn't cut as even as the the outside blades do...I think cause the wife likes to go balls out and too fast..Not shure... Anyway--- I had it on end and noticed that when I rotate the sharp side to the left, to line up the edges it's fine... when I rotate it to the right blade, ( sharp side ) They are about a fourth in. off..
I'm guessing that the deck is bent in the center,, I was wondering if I could shim it or do I have to bend the deck back in shape.???
Any thoughts...??? sodi
Assuming the center blade is off kilter is not advisable. You will need to make sure all three mandrels are level and at proper height. Check all blades for flatness and that there are no extra or missing washers to throw off the blades.
Good luck.
  • Like
Reactions: sodisr
Discussion Starter · #4 ·
The blades are brand new,,,, as are the bearings in the mandrel.. If I rotate the side that is off,, to the other blade,, it is even.. and if I rotate the outside blades 180 degrees, Same thing..
I would then check with a flat edge from one mandel to the next and look for a gap and then check that mandrel for square (mounting) before assuming the deck is bent.
  • Like
Reactions: sodisr
And look at the drive hub and rivets to be sure a hub isn't slightly off or a rivet missing between the blade and drive hub.
  • Like
Reactions: sodisr
Premium Member
The decks are tough, but can be bent. The footprint of the bearing housing isn't that large, and some localized deformation can happen. Analyze where and in which direction it is deformed. Use a large crescent wrench and/or a BAH to bend it back flat.
1 - 7 of 7 Posts
