1 - 5 of 5 Posts
Well, I tore into the mower deck to get it ready for the 1256 when it finally gets finished.
The mower deck itself is solid with quite a bit of pitting on the underside. It looks like I will be needing some parts, I'll be watching ebay, any help would be appreciated.
Belt Cover 1721067
Blade drive pulley 1716763 at least 1
Drive hub 1719040 (3)
Retaining Ring 1185708 (3)
Rivet 1177330 (6)
Idler Pulley complete assembly (1)
I may need a Bearing housing with bearings, I am soaking them right now in PB Blaster to see if I can get them loosened up and or removed.
Old, but not dead -- yet!
Bigdaddydon said:
View attachment 14220 View attachment 14219 View attachment 14218 View attachment 14217 View attachment 14216 View attachment 14215
Blade drive pulley 1716763 at least 1 I can't tell what is wrong with yours from the pic. ....If it is just two small chips from the rim, I think it is still useable if you can't find a replacement, provided the keyway in the pulley is not worn.
Retaining Ring 1185708 (3) Standard retaining rings available from some hardware or auto parts stores, or bearing supply houses. ....You just need to know diameter of shaft, and thickness of retaining ring.
Idler Pulley complete assembly (1) The idler assembly was not sold as a complete unit. .....All the parts were sold individually. .....The idler pulleys are not unique to Bolens, and should be available from most lawn equipment dealers. .....You need to know the O.D., I.D., and the width of the pulley. .....Most of the idler pulleys had a hub (inner race of the bearing) that was offset (longer on one side than the other). .....There were often spacers on one side of the idler to keep the pulley from dragging on the flat plates.
The stud that the idler assy pivots on needs to be free of rust, and needs to be fairly smooth. ......The nylon bushings were also used by other brands.
Try to save the housing, if at all possible! ....Bearings can be purchased through many sources. .....Try to keep from destroying the spindle shaft, as well.
Discussion Starter · #4 ·
Thanks Bruce, The drive pulley is pitted and very rough i'm afraid it would cause the belt to wear to quickly. My idler pulley assembly is rusted through and must be replaced i see one on ebay that i'll try to get.
I am still working on the housing, patience will get me there I think. All spindle shafts are in good shape.
It looks like my big issue will be the Drive hubs, has anyone found an alternative?
1 - 5 of 5 Posts
