1 - 12 of 12 Posts
well here you are, for those who like photos (which seem to be almost all) Tire Wheel Automotive tire Tread Vehicle brake
my first time doing this so please be tolerant,,,,
I'll just wing the description since I do not actually see them....
the first one is to show the enormous weight box at the back, next a side view just to show overall condition, then there is the one of the 'tool box' under the seat, I was actually surprised at the absence of rust. The shot of the transaxle shows an amazing absence of oil! I hope this is a good sign. The last photo shows not only my Massey 10, but also my amazing Tecomaster 6 with a China 6.5 HP motor from Princess auto ($99. on sale) and a Muncie 4 speed shift knob (the only thing left from my insanely fast '68 Z 28 Camaro.
I type super slow, so I really hope this all uploads...
That's a nice looking "10".
Premium Member
You found a nice Massey Ferguson MF10. The weight box is definitely on the large side but at least you know you have plenty of room to put weights in. You could also use it to haul tools for various jobs around the house as well.
It has a lot of great things going for it. The sheet metal is all nice and straight, has the hub caps, the grill is in really nice shape. Just need a headlight bezel which I think 99% of all of the Massey's got broke sometime in their life. You can find used ones and there is also a fellow making reproduction units that look nice. Get a headlight kit and she will be good to go.
Discussion Starter · #7 ·
hey,
i actually do have the headlights and that piece that holds them in(came in box when i picked up snowblower, which seems to be in really great shape), but no 'rubber trim' to go under the headlights(the trim is on the piece that holds the lights in place)
Looks good. Nice find.
Yes, that does look like a very nice tractor indeed!
You know, if you fill that weight box with cement, it would weight about the same as my lead one does! (my calculations say my box would need to be 28" to match the same as my 4" thick box with cement.) OR, you could fill that on with lead and it would sink to the hood! LOL
For the rubber headlight trim, you can slit some windshield washer hose (new from NAPA) and just sit that in place. It should work just fine.
Discussion Starter · #10 ·
nice job on the mf 12 you have on you tube. I've been studying all the details and meticulous work that you have done to it (weight box, plow, etc.. etc..,) I was thinking along the same lines, as far as adding weight to rear- dense, compact, and visually pleasing. My hunt is already on for cheap lead(free if possible)
as far as 'my present weight box', I figure I should fill it with water in spring and park it outside by the bird feeder, LOL
It all depends on how nice that box was built. It looks pretty decent in the photo, you might be able to just cut it down a ways and fill it with lead. I think given the width/height, 4" to 6" is the most you would want to go. At 6" you will be well over 350lbs though!
If I were to do anything different, I would drop the holes that go through the box, and make it with angle iron to bolt it on. Those holes are a pain to line up and it's hard to get the nuts on the back. All around, it's hard to line up and bolt it on. I think welding angle iron to the top and allow that to stick above the box would make it much easier to put on. However, it would not look as good!
PS, thanks for the nice comments too!
1 - 12 of 12 Posts
