1 - 20 of 199 Posts
Hello,
Here are some recent pictures of the MF 14 I bought today. It looks like it will need lots of TLC.
Has anybody seen my coffee ?
Looks like a diamond in the rough to me in overall pretty good shape. Looks like most of the rough is just cosmetic. A little sprucing up the cosmetics,change the maintenance items and you have a very nice tractor. I really like the those MF 14's. Makes me want another one...
It looks like it's just been neglected, not badly abused. I think you're right, it just needs some T.L.C. and you'll have a good tractor to play/work with. Guess I have trouble separating work and play, lol.
I'm sure glad you got this, you have had me nervous you were going to loose it. I never mentioned this but I have been watching this since it came up a month ago. The 14 & 16 are hard to find & most MF fans buy them regardless what shape there in for a restore or for parts. When you mentioned it last week I thought I wouldn't be able to sleep at night if I got this. This is about an hours drive from me. Then you kept asking for info then you said you haven't bought it yet & I thought WHAT ARE YOU WAITING FOR ! It does need some work but nothing that can't be done. I would copy & paste the PO pic of the front, it looks so sad but happy now in your garage. Jump around on here & see what some of the others have started with....a lot worse than YOURS. I would take this diamond in the ruff totally apart & do it right. Your biggest advantage is your a part of GTT so you have plenty of help. Congratulations, now I can take this one off my list....joyfully. :thumbs:
  • Like
Reactions: MYMF10 and Gabriel
I think you got a good deal and it's mostly all there. Just go thru it and you will have a great Gt. Just needs some TLC and it will look like new again. Congrats!!
  • Like
Reactions: Gabriel
Great looking tractor, used but not used up. :thumbs:
I'd start with the blown head gasket and try and patch that muffle then see how it runs, then move on from there.
Nice project, good luck with it :beerchug:
That looks like a Cub muffler that's on it. Good luck with it.
  • Like
Reactions: Gabriel
Congratulations. It looks pretty good. Thanks for those nice photographs.
  • Like
Reactions: Gabriel
Discussion Starter · #12 ·
Thanks for the encouragement! I am very grateful to find an MF 14. I had to wait for better weather to pick it up, but it turned out to be a rather cold, snowy day(not what the forecast had originally said when I set up a pick up date). When I started looking it over, I found things I you couldn't see from the pictures on Craig's list. It was a bit discouraging, but I know that once it is restored, it will be better than any new garden tractor you can buy today. I hope you all don't mind questions, because I will probably have lots!
Discussion Starter · #14 ·
Hello again,
How has anyone here repaired the plastic dash on one of these? Mine is cracked and missing bits of plastic on the bottom.
Discussion Starter · #15 ·
Is the muffler suppose to have any other braces to support it besides where it bolts to the engine?
Gabriel I'm presently working on my dash panel. Mine had already been poorly repaired so I ground off the previous fiber glass & cleaned with solvents to get rid of any dirty, & oily films. I clamped the cracks to even out the surface & applied some epoxy. I will fiber glass with mesh this area smooth & as MH81 mentioned use fender washers when I reassemble. Here is a pic I took for my restore documents.
Wood Auto part Tool Plastic Carmine
This is what I did to mine - which although not broken was badly cracked. First I tried to glue the cracks with superglue, but I knew that was unlikely to hold, so I cut some mesh to fit - tacked that in place with a bit of superglue as well, and then made up a solution of ABS in acetone (broke up a couple of ABS plumbing collars and dissolved them in half a jam jar of acetone). I painted that on with the bolts in place and let each coat dry before screwing the bolts in and out a bit to keep the holes clear. It took quite a few coats but by the end I had added another 1/8" in thickness to the plastic with some mesh in there as well. Then just for good measure I used oversize washers to hold it all down. Not the prettiest of repairs, but I think it will hold.
I built up the nose piece in the same way with some 3/16" rod bent to fit inside it for reinforcing.
1 - 20 of 199 Posts
