1 - 15 of 15 Posts
I bought this lawn tractor back in November. I believe that it is a 1967 (55300) or 1968 (55301) Toro Suburban 10 lawn tractor, I cannot find a name plate anywhere on the mower. This has the cast iron 10 HP Kohler engine. I bought this because i needed a mower and i have been interested in getting an older lawn tractor that worked but needed some minor work.
When i bought this, the only thing that was needed was the belt for the mower. I have been having trouble finding the correct size belt. I cannot find anywhere that lists the size belt that is needed, I found the parts manual and it only shows the drive belts. I have tried a 5/8" 75" long belt and it seemed to be too tight, i then tried a 5/8" 76" long and that pops off the pulleys when i engage the mower.
I was hoping someone would be able to help me figure out few things that i have questions on.
What size belt is needed for the mower?
Where should the name plate be that states the model number and serial number?
Any help will be appreciated.
Thanks,
Jeff
Freedom is not Free. Thank those in uniform for yo
Welcome to GTtalk. Please check our manuals section and see if there are any additional manuals that may give you more info. I would think a good lawn mower shop should be able to figure out what size belt you need. I'm sure one of our members will probably know.
Discussion Starter · #6 ·
Thank you for your quick feedback and the info. This Sprinfield manual has helped out a lot and actually showed the main drive belt for the mower, I just need to find the dimensions of it and where to buy it.
I do have a copy of the manual for the Toro Suburban 10/12 but it did not show the mower attachment parts list.
:wave: Welcome to the forum! I bet you need the manual for the deck to find that belt!
  • Like
Reactions: jmbig1
Just a thought but it looks like you may have a mouse next under your engine tins, the batting that is on top of the motor is usually a good sign that mice have gotten in and made a home. This can cause a fire or can cause overheating and engine failure from lack of airflow. Just something to check out and it will give you the opportunity to get to know your machine better. Good luck!
Discussion Starter · #12 ·
Thank you for your thought, i will have to look into that more. i know the person who owned it before me kept it in a barn, maybe this is just left over from then. I will have to get in there and clean it out to make sure I wont have a fire or failure.
Discussion Starter · #13 ·
55300 manual including mower deck
http://www.wheelhorseforum.com/search/?q=55300&type=downloads_file
55301 manual but no parts list for mower deck
http://www.wheelhorseforum.com/search/?q=55301&type=downloads_file
Gates replace the 7-0630 belt with a double 3/8" belt tied together by a band on the outside. 75" long Gates # 3V750
Looks like the 42 SD deck was model 59004 from 1967-1971.
Garry
Thank you for this information. This has been very helpful, I will get this belt ordered so i can start using the mower.
Discussion Starter · #14 ·
From the picture it looks like the belt is riding high in the pulley, are you sure it doesn't take a 1/2" belt? Nice tractor by the way.
Looks like the belt that is needed is 3/8". At the store i went to the only size i found was 5/8" so thats where i started, turns out it was way too big and is sitting too high on the pulley.
Thanks,
Jeff
Hi Jeff,
I know it's been several years since you created this post, but I was hoping you could help me out? My husband got this same tractor about two years ago as a restoration project, and it's almost complete. I am having trouble with a main style component, and i stumbled across this thread. When we got the tractor, it was in excellent condition, minus the seat and backrest cushions. I am capable of custom-making a new seat for it that looks original, but the parts of the seat that are left are incredibly rotted out, so I am having trouble even getting general measurements to go off of. Your seat looks to be in decent shape. Could you possibly take some measurements of the seat and backrest cushions for me so that I have something to go off of? The pictures of orginial seats online help in terms of style and trim, but the actual shape and height, etc, have been stumping me. If you still have this tractor, and could provide me with some quick rough measurements, I would greatly appreciate it.
Thank you!
-Alison
1 - 15 of 15 Posts
