1 - 5 of 5 Posts
I had to pull the one out of my second snapper 1650 as the first was cracked up pretty bad. Now I need a new casting. Just need the cast aluminum box.
Take pics and get part numbers from the aluminum gear box. If It's a Ross, the box was most likely used in many other tractors.
MANY other brands had this box - Ross - (Ford, Cub, JD, WH, etc) However, you have to be careful of the shaft length, box is same but shaft be different length. If you can remove the shaft tube - which can sometimes be impossible - you can use your shaft/tube.
1 - 5 of 5 Posts
