1 - 14 of 14 Posts
Premium Member
Years ago I had a collection of garden tractors from most makes but I got rid of them all due to back issues. Well, the back is fixed and I needed a Bolens tube frame. I repaired my BIL's 850 a couple years ago and tilled my garden as payment. I purchase a tiller a few weeks ago for $100 and searched craigslist for a tractor and snow blower. I found a blower for $100 and a 1220 for $150 and purchased them both the same day. (They were within 15 minutes of each other.)
The guy I bought it from didn't know much about it because it belonged to his BIL who had passed away. After a little coaxing the Tecumseh started right up. It smokes a bit but I hope that clears up with some Sea foam running through it for a while.
My big issue is getting the tractor moving. I put it into what I thought was reverse and the motor started to lug and it didn't move. I tried first, second, and third with the same results. I then put it into what feels like neutral and it moves forward!
The posi-traction knob is disengaged and the pin on the right side is out. Logic tells me that it shouldn't move at all, but it does. I'm going to do the end-play adjustment tomorrow if it's warm enough.
I'd REALLY like to get this thing running before the next snowstorm. I'm planning to use it at the church I take care of. I'm getting tired of pushing snow blowers around.
Any help would be appreciated.
tnx,
Stan in MA
Welcome to GTT. There are a bunch of very knowledgeable Bolens people here. Give them some time and they will offer advice. In the mean time you can check out our Manuals Section. You are allowed 3 free downloads per day. There is an excellant(and large) Tube Frame Repair Manual and there are engine manuals in their own section.
At this time of the year, I become concerned about water/ice in the transaxles. As long as its not frozen, you can drain the water from the bottom. Good Luck, Rick
:wave: Welcome to the forum! I hope it's not too much of a challenge to get this moving again!
Welcome!
Judhing by the way that shifter is leaning in the photo I think your shift forks poped out of place and need to be reset. Right now the gears are probably binding and trying to go 2 gears at once.
If the tractor still moves with the pin out most likely the hub has rusted together.
Premium Member
Discussion Starter · #5 ·
The shift forks idea sounds about right. I'm warming up with a fresh cup of coffee before going out to open it up.
I printed out the 100 page "Medium Tube Frame Tractors" Service and Repair Manual.
Premium Member
Discussion Starter · #6 ·
Problem solved! :dancingbanana:
I opened the transmission, looked in, and said to myself "Shouldn't there be gear oil in there?" I drove to Napa, picked up three quarts of gear oil, Sea Foam, and a new spark plug.
I drained the tranny and only 20 oz. came out, even with the front of the tractor elevated. Since I had the cover off I took advantage of the situation and poured the gear oil over all the forks, gears, and whatever. With the clutch depressed, I went through all the gears and the two ranges, it worked great. It looks like my reverse geat took quite a bit of misuse as part of the teeth is chipped off. Still, it works for now. I laid a bead of Permatex down and closed the case ... DOH! I forgot to align the shifter and range selector before closing the case. Open, align, close.
I tested it again and everything looks fine. I can't test it under power because there's a concert at the church and the 1220 isn't the quietest tractor.
Quick question: Are the gears from the standard 3-speed tranny interchangable with the 6-speed? I have access to a parts tractor that had a tree dropped on it, but the gearbox is okay.
Thanks for the help guys.
The cluster gear that often wears on the 3 and 6 speed tranny's are not the same, the 6 speed has the 3 gears on it and the 3 speed has 2 gears with the smallest being built right into the input shaft.
You did use Mineral 90 weight gear oil and not synthetic right?
Sorry for my ignorance, what's 'sea foam' as I have not heard of it here in the UK. Thanks
Premium Member
Discussion Starter · #12 ·
I ran the tractor this afternoon and it shifts fine, reverse is a bit tricky due to the damaged gear. My shifter is a bit loose and it became misaligned during my testing, stuck in first. Until I fix it I just need to be careful when I shift.
Good news your 1220 is up and running. I have a 1225 which I think is an awesome tractor - very strong and reliable. Out of curiosity what was the Craigslist asking price on your 1220?
Premium Member
Discussion Starter · #14 ·
The price was $150. Once I saw the tractor was complete, I didn't haggle, $150 was good enough. Are you really on the Cape? I'd be interested in the 1225 but that's too far for me.
1 - 14 of 14 Posts
