1 - 8 of 8 Posts
I'm a newbie to this forum, but no stranger to Bolens! My current fleet is 4 tractors at the moment, a 1054, H-16, and recently two estate keepers, a EK7 and an EK10. the EK7 is pretty beat, but all there, Mostly original, running (barely), and has the mover deck and a snow blade. The EK10 was engine swapped with a W1 390 Wisconsin, but isn't currently running, but seems overall to be pretty tight. The questions I'm looking for guidance are
the EK7 slipyoke on the PTO driveshaft is pretty loose at the rear of the machine. anyone have luck in finding replacement slip yokes for these?
also, I see "drive belt" listings for the EK7 and EK10, but very little description on which belt is for the low speed and which is high speed. Anyone have belt#s with high and low speed designations?
and does anyone have a source for the brake "block" on these?
Thanks in advance for the help!!
Discussion Starter · #4 ·
I kinda figured about the belt on the swapped one. Figured I might get lucky on the swapped one. I think it might get another swap, as the engine needs an ignition coil, and they seem to be real pricy and hard to come by However, the EK7 is still unmodified, and has a low speed belt on it.. The pto shaft play is in the splines on the slip yoke. the u joints are still tight. The pto pulley has a bit of a wobble to it, so it looks like this might have had an impact on the bottom of the unit to the pto shaft. Like I said, the EK7 is pretty rough mechanically.
A Little Off Plumb
If the PTO splines are similar to the tube frame series PTO you could repair the splines by building up the splines on the shaft where they are worn and bushing the slip yoke and pulley and cut new splines the way I did in this thread - a bit of work but it can be done http://gardentractortalk.com/forums/topic/52146-bolens-1050-tube-frame-pto-shaft-repair/page-2
Deceased
If u plan on pushing any serious snow with an EK o hope u have chains an weight on the rear, they came with a big cast weight on the rear did u get that with 1 of them? I have a guy that would probably kill u so he could have it. There out there u just gotta find them. I drove 2 hrs to get mine but $60 the price was right
1 - 8 of 8 Posts
