So I have yet to have any success getting this s12d running. I have cleaned up suspect wires,changed fluids,plug,air filter, etc. when I put a voltmeter up to the plug it showed I am getting like 5 volts. I went through the carb as well. Hooked a brand new battery up. Put a new starter generator on it. It's a slug and it hisses or has some type of air sound to it when I turn it over. I looked at the points and they look clean. It acts as if it doesn't have spark and the engine does not turn over very fast, I checked the tent ion in the belt. When I have had the engine turn over faster it still doesn't try to start. It seems like a spark or fuel issue but I haven't been able to get it started with fluid either. Do I not have enough voltage or do I need to check compression or what?
