1 - 5 of 5 Posts
i have this 1966 Bolens 850 with 10hp wisconsin.....need a little guidance ...as im new to these machines...i cant get spark to the plug....i checked points.....continuity from them to the ign. switch and ground..good.....points look new...as well as condensor....so maybe the wire itself? or ??...thanks
The Wisconsin engines used a similar magneto to many other manufacturers. The pickup area and the magnets need to be rust free and the gap should be about the thickness of a business card. Also, check to see if the magneto is grounded well. If there is a separate wire going to ground, make sure it has good connection also.
1 - 5 of 5 Posts
