1 - 5 of 5 Posts
Rust Wrangler
My MTD project went dead in the water so I figured it was time to pull my MF10 in the garage and do some work on it before garden season gets here. I noticed that once she started, the variable drive shifter felt "crunchy". The drive needed adjusting anyway so that would be a good time to check out what was causing the stiffness in the lever. Here's what was making the crunchy sound.
Wheel Motor vehicle Automotive tire Bumper Automotive exterior
What you see there is just a fraction of what was in there, most of the heap landed on top of the deck. No damage done and the variable drive is now lubed and adjusted. There is however a very upset squirrel in the neighborhood.
Moth Balls or dryer sheets do work. I was thinking of making a cage I can bold under my engine shroud that will hold 2 or 3 moth balls , I have had to take a perfectly good running engines apart to get the nest before, then yet I got a few perfectly running engines thats to them as well. Seems that most tractors come with cheese flavored wiring.
Rust Wrangler
Discussion Starter · #5 ·
I haven't had mice problems in a long time, knock on wood, and I was surprised that a squirrel had made a cache in one of the tractors. At least he wasn't interested in the wiring. Mice are some nasty critters to clean up after. I'll have to try the mothballs and dryer sheets, maybe mothballs tied up in a dryer sheet and see if it works on squirrels.
1 - 5 of 5 Posts
