1 - 15 of 15 Posts
G
so i went to start the bolens. after getting a generous donation of a keyswitch and key from my buddy. and only once every few seconds will it spark. he told me the flywheel magnets may be rusty or dirty. or the magnet on the coil might be dirty. so i guess ill go clean them with emery paper and see what happens.
G
Discussion Starter · #3 ·
there was no switch in it. so no clue. i wish people would just tell me tractors have problems instead of selling me a big surprize
Premium Member
Not sure what motor you have in the tractor but it could be dirty points as well.Larry
G
Discussion Starter · #6 ·
its a tecumseh oh140. its in my new g14. the guy said it sat a year. it has a battery in it dated 2009. so i cleaned the flywheel magnets, 2 little nubs that go past the coil. cleaned the coil magnet. then i had no spark but my friend says i need to gap the coil with the back part of a match book. so i did that and now i need to get the engine tin on and pray its not my coil.
G
Discussion Starter · #8 ·
alright i gapped it. all is well its sparking in the same pattern as before. now i looked in the tecumseh service manual and under intermittent spark. it says to: "Disconnect ignition cut-off wire at the engine. Crank
engine. If spark, check ignition switch, safety switch
and interlock switch. If no spark, check magneto.
Check wires for poor connections cuts or breaks."
now my question is. where is the ignition cut off wire?
If you are the flywheel side of the engine, there is a small insulator at the 8:00 position. There are 2 wires that connect to it, one goes in under the housing, and one goes back to the switch.
Do yourself a favor, if you disconnect this wire and still the same, check the kill wire going under the tin and make sure it isn't grounding on the flywheel periodically.
1 - 15 of 15 Posts
