OK guys I picked up a log splitter with an 8 hp Briggs & Stratton motor the horizontal. When I first got it it would fire up with the choke on shortly run and then die. I cleaned the carb and still had the same symptoms although I was able to use the log splitter for about 30 minutes with the choke on. Anyway, I bought a new carb. After installing the new carb I have the exact same problem I put a clear fuel line on there and I can see it flowing to the carb. if I shoot starter fluid in the intake it will fire up and run but shortly after it will die I know the carb was clean because it's brand new. I am pretty handy with small engines however this one has me stumped for this not seem to be a fuel issue although the symptoms are very much like a fuel problem
