1 - 12 of 12 Posts
How hated would I be in the Massey community if I took that tin cover that is only on the hydro's (in front of the seat) and say... french welded in a length of pipe, cut to match the profile, in order to create a cup holder? :smilewink:
I was looking at it while I had it off, and it's pretty much empty under there. If I used some pipe that would be about the size of your typical cup holder and capped the end, then drilled a couple drain holes, I could weld it into the pan on the bottom side. Then the pipe would be cut and ground flush to the shape of the shield and welded on the top side, again, being ground flush. It's not something that could not be undone easy enough, and it would be really handy. So what do you think? Should I go for it or not?
:anyone:
I guess what ever you want to do with it,it's yours.
It all depends on what you are looking for. A true resto? Then no way. A restored tractor that you enjoy? Then why not?
I'm a deer hunter. I like to track or still hunt when theres no snow. To make my rifle "better" I had the barrel cut down to carbine length and the reciever drilled and tapped to accept a reciever sight. That's my foul weather gun. My other scoped rifle is cut down the same way and also has a painting on the stock of a 14 point buck I shot back in 2004. People have told me that I "ruined" these guns because they are not "factory" anymore. They are correct in that statement, but they are still beautiful to look at, and because of the faster handling the carbine length gives me, they perform better for my particular needs. Would I do it again? In a heartbeat!
As has been said that if you are doung a true factory restoration then I would asy don't do it. On the other hand if you are fixing it up as a user tractor I say go a head and make any changes you want to make it fit your needs better. As a worker tractor it is a tool that you are using and any thing you do to make it more user friendly makes it more valuable to you.
Discussion Starter · #8 ·
It will be a resto in a way, but I do not mind improvements as long as they are not something that can never be "un-done" An hour or so with a welder and paint work, and the cup holder is gone. It's like when I cut down the front wheels on my 12G and narrowed them for the tri-ribs. If I wanted to just put new rims on, it has been put back to stock. It takes me about 2 hours to mow, so having a bottle of water on hand is nice. I figure if I do this, it will look all but fully original and much better than something stuck on the fender. But the simple replacement of that one panel, or repairing the hole will fix it for good.
I think I am going to do it... I am thinking that one of the exhaust pipe female connectors may be perfect. They should have a pressed ring on the center of the pipe that will work to keep the water bottle off the edges and may cut down on paint wear.
Premium Member
I don't see anything wrong with it. Like has already been said. I think the other factor though is in the approach and how you pull it off and how it turns out. When it is done right it doesn't matter.
I haven't been here long, buit from what I've seen from his welding on his other projects, we shouldn't have much to worry about. I'm thinking it's going to look like a factory piece when it's done! :thumbs:
1 - 12 of 12 Posts
