Looking at the picture it is really hard to say. What have you done to clean it up. What is your intention for the engine. Where else did the water go.what should I do?
i did not pull the piston, but I have ordered a set of rings so I will be cracking it open and honing it properly. I do not intend to go to the expense of new pistons and proper machining, though. Thanks! EdDid you pull the piston to hone? That would be the best. With the piston out you can check the rings for rust and clean everything. then just put it back together and give it a try. At this point you have little to nothing to lose. If it smokes to bad to put up with and won't stop it will still be as valuable as it is now. Removing the piston also gives you the chance to inspect the rod bearing.
Don
Thanks. Ordered rings and gaskets. Hoping to get it going without further expanse! EdPersonally I would pull the piston, hone the cylinder till clean and then measure the bore. If the bore is with in specs then install the old piston with new rings. (not a good practice to put used rings back in a cylinder) If the bore measurements are out of spec then over boring the cylinder and an over sized piston & rings will be required. Do it once, do it right & enjoy it a long time.
