1 - 8 of 8 Posts
i have a Bolens that is powered by a 2 cyl Onan. I made this tractor to just blow snow and it has been working fine
until yesterday when I went to start it and it won't start. I'm going to buy a compression tester this afternoon and
check out both cylinders. I have spark,fuel and even tried starting fluid. No luck.does anyone know if the valve guides
on an Onan are problems? This thing was running real strong and now nothing.
Thanks Phil
Premium Member
Welcome to Gttalk!
Yes Onan engines have been know to have valve seat problems.
But, usually just one cylinder at a time.
The engine would stil run, just at reduced power.
I'd suspect a timing issue. Or, lack of spark.
How did it fail. And, how did you test it?
And where abouts in Mass are you?
Joe
Discussion Starter · #3 ·
Joe,
The tractor just wouldn't start after blowing snow for an hour in the morning.
I'd like to thank all the members for their ideas. I tried everything I could think of
except for checking compression. Bingo!! Very little in both cylinders. I pulled one head
this morning and put that cyl.on TDC and I was able to turn the intake valve by
just pressing on the head of the valve and twisting with my thumb.I took the lifter
covers off and reset the valves and it started right up. I guess I'll have to keep an
eye on this before snow fall next year.
I live in Essex MA. and have seven other Bolens tractors. One I've had for about
twenty years and that started me collecting them for spare parts. My wife says that
I have enough so I'll be going to Eliot to the tractor show next summer to try to
reduce my stock of tractors.
Thanks again everyone
Phil Stevens
Glad you figured it out! I was kinda wondering if something like that could be an issue!
Premium Member
Phil,
Those Onan's have aluminum blocks and hardened steel inserts for the valve seats.
Sometimes the seats get pounded down into the block. And, sometimes they just become loose!
Sounds like you got lucky! But, you want to keep an eye on that.
What model of Bolens do you have? I have three large frames, an 1886, a HT 20, and a HT 23 with a loader.
Only the loader is running. I've been using it to move snow, snow and more snow!
I just picked up the 1886 in Rowley. I always go to the Eliot show. It's in my backyard!
Joe
1 - 8 of 8 Posts
