1 - 3 of 3 Posts
Have been looking for a parts manual or break down for the 1658 , H16XL tractor. I have it for the gear transaxel but have not located on for the Hydro model.
What I need the size/type of of vibration insulator between the motor and the drive shaft coupler. Both pieces are the triangular shape but are they a bolt through or do they bolt to the isolator separately, like in the 1050 series, etc. The drive shaft was bolted solid to the motor shaft with a 1/2" nut as a spacer ?? Plan to make the spacer or isolator from thick belting.
Thanks much for any advise or pointing me in the right direction.
  • Like
Reactions: blackjackjakexxix
Discussion Starter · #3 ·
Thanks much for the manual. It helped a lot on getting this tractor back together the way it is supposed to be, sortove.
1 - 3 of 3 Posts
