1 - 11 of 11 Posts
Masseyholic
It's rough, but i think it's savable :D. The dash is junk, there's no hood, no grill, the pto shaft under the frame is missing and a few other parts. It has an hh120 that turns over with good compression but no spark, all the gears seem good and i already got the bent fender looking (similar) to the good one and i got all 4 tires to hold air.
My plan it to make it a work horse, so I've also got my eye on some parts on ebay!
Motor vehicle Automotive tire Hood Automotive lighting Wheel
And last... does anyone have the demensions of the rod the goes from the lift lever to the pivoting shaft that would lift the mower, blade....ect
It's number 35 here under the first tab (Frame, Brake, and Lift Linkage)
AGCO Parts Books
Thanks for any help
Masseyholic
On the plate on the side it says MF10. after looking the engine over it looks like the origanal engine but with a different blower howsing. a diesel repower came to mind but i think i'll stick with what i got, my uncle has two solid state ignition vertical shaft cast iron engines and one of them runs so i think i'll try to make the origanal SSI work. If not........possibly Diesel :D (If money allows it)
Masseyholic
Discussion Starter · #7 ·
I should have been more specific of what i was looking for, Thanks Will that's the one i was try to describe. if you could get me the length sometime that would be great. (it's not a rush). I wont be using it any time soon being i don't have the PTO shaft. once i locate that the only parts i'll be missing is the hood and grill. there's one on eBay right now, i think in a month if it's still there i'll buy it. and because my plans for it are to make it a work horse a hood and grill is not a necessity.:D
I will get you that measurement soon. I might have an extra one, but you could probably make one cheaper than shipping cost.
Masseyholic
Discussion Starter · #9 ·
to make one was my plan, doesn't look too hard to copy (even with my skills) LOL thanks again for the help
Electric Tractors
I just re read the post, I guess I didn't read it good enough the first time???
Masseyholic
Discussion Starter · #11 ·
I messed around with it a little tonight and found the SSI module to be bad, i took one of the ones from my donor engines and got great spark! i tried driving it but first i need a throttle cable and a little carb adjusting. The origanal SSI system seems like a easy and simple system to work with. too bad the don't carry them anymore.
1 - 11 of 11 Posts
