1 - 14 of 14 Posts
While on holiday last week I spotted this on ebay one eve. Put a bid on & waited to see what happened. Within no time it had reached my max & I thought I would loose out. Well in the end I won & went & picked it up a few days ago when I returned
Anything on ebay is a gamble as you dont know its true condition till you get there unless you go & have a look before hand
From the pics I had it did not look too bad. A good clean & tinker time & have some fun.
Well when I got there it was in worse condition than I thought. Its got 4 flat tyres, Engine is stuck, rear wheels dont turn & the rear fender is rotted through as it was sat under a tarp under a tree for 7 years!
The steering wheel broke off when i was loading it as steering is seized up
The old boy said it was a good runner when I last used it. Its got a 42in mower deck
Well I winched it up & brought it home. Sure it will clean up ok & find some new parts
Here is some pics
Sorry for your loss/gain.
Sometimes reading the description out loud helps yourself hear the in perfections even though your trying to look past them on FeePay, also, double check the description for a mismatch on was, or was NOT described after the purchase . I have found the last tip to be useful as some problems I have had were due on my part, and others were due to a poor description.
Sometimes being in a hurry can hinder decision making too, but most times...if it seems too good to be true.....it usually is!!!
Good thing is your here, so a positive outcome is bound to be had!!
  • Like
Reactions: HANKG
I must admit Chris, the pictures on EBay showed a fairly decent garden tractor. Still for £200 it is not a lot of money and as you say you can get a few parts to get it going again.i got a decent Wisconsin engine sitting in my Lock Up that might be of use! :) Good luck with it.
Discussion Starter · #7 ·
I know when I put the time in it will clean up well & run a treat
Tyres can be fixed & parts can be found. The rear fender hopefully can be welded up. Was working with a mate today welding up a flail mower & I joking said does he want to have a go with it & he said yes. Cant get any worse.
The engine is a tech Andrew & think its just the belts stuck on the pulleys causing it not to turn
Anybody got a steering wheel in good order they want to sell me :thumbs:
Hi Chris, must admit didn't think it would be that rough, but it wasn't a lot of money and i'm sure you'll fix it up within time. Shame about the steering wheel breaking as they are quite hard to find. You've said it has a tech engine, my G10 has got a Briggs & Stratton. Will post some pics of my viking seeder which i purchased at the weekend. Can't at the moment as my phone screen has broken and had to put my sim in a very old phone without camera.
Discussion Starter · #10 ·
It did come with a useable 42in deck. Belt covers bit scabby but with a good clean up & check over it can be used back on that tractor or my G14 when I have removed the loader & put it on the 1556
Dave, a pic of the engine carb which needs some TLC
I must admit I thought the G10 had a Briggs in it Chris but just had a gander at the Tractor Data site and I see that it's a Techumesh engine.
The deck itself is an added bonus Chris.
Discussion Starter · #12 ·
Iains G10 also has a Techumesh engine in it Andrew
His tractor works also :dancingbanana:
Premium Member
G10 1055-01 had the Tecumseh.
G10 1055-02 had the Tecumseh.
G10 1055-03 had the Briggs.
G10 1055-04 had the Briggs.
:thumbs:
Bolens
Good purchase Chris, I am sure you will get it fixed up. I have two G10's both are 1055-02 like yours and have Tecumseh HH100 engines . I dropped a new carb on the G10 I regularly use, it was not expensive.
I found that a G10 is a good grass cutting tractor and I used mine for grass cutting duties last year when my HT23 was being naughty.
The fender on my second G10 is rusted out exactly the same as yours.
Iain
1 - 14 of 14 Posts
