1 - 5 of 5 Posts
howdy,
These are the latest pictures of my mf 10 being primed. I have also included some pictures of the mf 10 and deck I got for $50.00 on ebay. I hope you enjoy.
Also, can you tell from the picture of the deck if I have all the mounting hardware or not. That is all that came with the deck.
Tom
Tom,thanks for the pics. You're doing a good job.
  • Like
Reactions: tomkuchenbrod
Electric Tractors
the red frame in the 3rd picture is a 66 frame, has extra engine mounting holes and if you look underneath you will find a missing center rib under where the engine sits.
The other frame is 67 and up.
Looking at the deck, as stated, you are missing the bracket that the lift rod connects to. (And the gear box, this bracket bolts on with the gear box) You are also missing the main arms that go to the frame, however these are very easy to build. They are just flat stock with simple holes. The front, and maybve rear roller is missing too. I can't see the rear roller, but there is a part that looks like it goes to the rear roller on the ground. There should be two cast iron brackets that hold the rear roller in place too.
You do have the front mount plate, that is something that is easy to misplace with the deck, and alot harder to build!
Here is my restoration thread, some photos may be of help to you in there.
http://gardentractortalk.com/f2-massey-ferguson-snapper-amf/mf-610-mower-deck-restoration-6068/
  • Like
1 - 5 of 5 Posts
