1 - 15 of 15 Posts
In the process of finishing up the rebuild on my MF8 this morning, after bolting the hood back on the air cleaner on the chinese clone engine (predator) wont let the hood close all the way. I have this engine in until I have more time to get a tecumseh I have on my shelf running and will put back in the tractor. I dont want to cut the hood so it will close, has anyone made or purchased an aftermarket air filter that takes up less room than the bulky plastic box that comes with these engines? Here are some pictures; with the filter on the engine Automotive tire Vehicle Motor vehicle Bumper Automotive design and with the filter off Motor vehicle Automotive tire Automotive design Bumper Automotive exterior .
Premium Member
That is going to be a tough one to get around. The angle of the carb. puts the filter in a bad spot. I hope someone here can help you out as that is a nice looking tractor.
Discussion Starter · #4 ·
The box has the tube for the air to go through with a square foam piece at the top for the filter. I have been looking at some go cart forums there are some adapters to put a round filter on like the picture. I was hoping to find a type of adapter to bolt on to come up the side like the big farm tractors have.
Discussion Starter · #7 ·
Since it's supposed to be a temporary engine, how about just leaving off the cover and leaving the air filter and lower portion in place?
Mike
The cover holds the foam air filter piece. The more I look at it the more it looks like it is going to be a custom fab project and time to go to town to find some round tubing.
Freedom is not Free. Thank those in uniform for yo
How does the air filter on the clone bolt up? What about an air cleaner from another engine? Maybe a lower profile one off that could be modified to fit.
Anything Red . . .
It sounds like you answered your own question. Now answer mine. How did you get the predater gas tank to just line up with the notch in the hood?
Discussion Starter · #10 ·
Air filter bolts to the carb, the carb comes off the block at a 45 degree angle. I looked at air filter from a tecumseh but it wouldnt clear the grill do to the angle.
Just lucky, when I went to bolt the predator engine to the engine plate the holes front to back were the correct distance but the width was too narrow (i think going by memory from last year). I drilled 2 more holes in the engine plate to bolt the engine to and after bolting the plate to the frame it just lined up.
After looking around yesterday on what or how to fab up and adapter to the carb for a filter I decided to buy a kit similar to the one above for now. I have an tecumseh engine out of a MF7 my son gave me. I pulled the head off to inspect it, other than carbon build up it looks good. I changed out the oil and turned it over with the starter and it has spark. Going to pull the carb off and clean it and see if I can get this engine running to go into the tractor. I have an 8hp tecumseh to go in it just need to get it running.
enjoyin the livin part of life!
I hope you realize with the amount of hop up parts available for the predator engines this minor air cleaner mod could be the start of a rather powerful project. :thumbs:
Aaron
You can make those little adapters pretty easy.
www.ombwarehouse.com
They have a ton of parts. My other hobby is minibikes. The predator clone can put out some pretty crazy horsepower numbers from a small engine. I've seen dyno charts of them topping 20HP. Spinning crazy amounts of RPM 9K+.
I have a predator 6.5 with a head, cam, carb rejet, filter, billet rod, flat top piston, thinner head gasket, billet fly wheel, that will just flat out scream down the road. Never had it dynoed but its putting out at least 15hp.
Discussion Starter · #14 ·
Update, the filter showed up Thursday and I took time last night to bolt it up. Here is what it looks like Tire Wheel Motor vehicle Automotive tire Vehicle Automotive tire Motor vehicle Automotive design Automotive lighting Automotive exterior . Only issue was I had to loosen up the bolt the grill mounts with and slide the grill forward and then once the filter was bolted down move the grill back so the hood is straight. I am thinking in future finding an elbow and tubing and bring the filter up the side of the engine.
Just waiting for the decals to show up that I ordered last week. Then it will be time to bring in the JD lawn cart for restore/repaint.
I agree it would look better going up but hey it works so your in business! Nice fix.
1 - 15 of 15 Posts
