1 - 9 of 9 Posts
Anyone know where you can get replacement parts ie motor for the electric hydraulic lift motors like on a 1200 or 1600 series? It is a Prestolite 106152. It was laying around our shop and I think the motor was bad. I took it apart and the motor is all rusted to a point I can't even get the aramature out.
Discussion Starter · #2 ·
So after some research it is a Hydraulic power lift off a MF10 522748 M91. The electric motor is shot so I still need to find one or get it fixed if anyone can help.
Cant help you, Dan. But at least I can bump this back up.
Pretty sure those things are kinda rare. You should try to get it fixed. Take it to an automotive electric repair shop. They do starters/ alternators. They might
be able to help you.
Discussion Starter · #5 ·
@ IamSherwood, do you think that little elctric lift will work on a 3 point? I can get the motor repaired for around $90-$150. I am not sure it will have enough power though to lift much. I plan on making or buying a rear blade and a rear 3 point rotary cutter (I have yet to make this). Neither one of these will be that heavy but they will stick out a ways behind the tractor making them more difficult to lift. I could make a hydraulic system for the tractor but that is a lot of work. If this electric unit wont work I would rather spend the money on the hydraulics.
Dan, sorry,I don't know how much umpf those guys have. It's electric over hydraulics, so it may produce enough.
Probably stronger than a straight electric linear actuator.
My understanding is that they attached to the manual lift lever. That lever also raised and lowered the sleeve hitch.
That sleeve hitch linkage also raised the rototiller. I have one on my 12. There is a lot of weight to that tiller, and
requires a good pull to raise it.
You might want to check with member Tweidman. I think he has one, and may be able to shed some light.
Discussion Starter · #7 ·
Would you mind sending me a picture of how it is mounted? Unless it is behind tin work then don't bother. I still have a lot of old Massey books I can probably find it in there.
missunderstanding here. I meant that I have a rototiller on my 12. I don't have one of those lifts to take a pic of.
Discussion Starter · #9 ·
Does anyone have a picture of how the electric hydraulic power lift is mounted to a MF10. Also any mounting or electrical information? I am missing the solinoid and need some info on it.
1 - 9 of 9 Posts
