1 - 9 of 9 Posts
Deceased
I got a set of wheel weights for my 1250 it has 15" wheels I want to put 2 weights on each wheel. The owners manual shows you need 4 long bolts and them oblong plates so do I only need 4 of them plates or what I just don't want to do it wrong any help would be great. Thanks sam
Sam, the bolts are not all that long. The little oblong plates that go into the recesses on those plate wheel weights have two holes in them to line up with the holes in the weights themselves. One of the holes is just large enough that the bolt shaft will go through it. The other hole is threaded so the bolt for the outer weight can be screwed into it. If you hacve the right equipment or a friend who can help you out, you could make those little oblong plates.
Just an FYI, when you put on the first weight, the bolts thread into holes left free on the hub flange after the wheel is installed.
  • Like
Reactions: 637Yeoman
Deceased
Discussion Starter · #3 ·
Oh I see I didn't know they were threaded in one of the holes of the plate
I don't have any spare ones, but I could provide pics if that would help, Sam.
Deceased
Discussion Starter · #5 ·
I got a good idea of what they need to be but thanks for the help
Premium Member
  • Like
Reactions: SC Farmer
Another stupid Q how do I start a topic, conversation, etc.
Open the forum you want the topic in and look to the right side for "Start New topic". Click that & your on your way!
  • Like
1 - 9 of 9 Posts
