1 - 13 of 13 Posts
Was wondering if anyone has powered a push mower on propane without
just dumping it into the air cleaner like most of the u tube video's I have seen.
I would like to build one using some sort of a fuel distributor after the carburator
so I could still use gasoline and with a regulator that shuts off when mower is stopped. I figure this would
make a good winter project.
I was looking into this about a year or so ago. Many tap a fitting into the carb venturi tube. Would this setup, along with a suitable 90 degree shutoff effectively isolate the fuel source as you would like?
Tractors have for years had systems, but look pretty complicated to me for just a little mower. I never figured out how the fuel amount was regulated on those kind that just dump it in the venturi?? Also on big tractors there are times of liquid, and then times of vapor, which it runs on, seems you would need to regulate that part??? Not worth the time, and what are you saving here anyway? Pollution? Ease of fuel on hand? Don't see the reason to want it.
Craftsman sold a propane powered walk behind that ran on desposable propane bottles.
Save on air pollution and fill the land fill with used propane bottles. Makes sense to me ? ? :wallbanging: :shoot2: :mad2:
  • Like
Reactions: propane1
I've scrapped them for pennies. They also make great bird houses. Make a hole, no CNC machinery required. Bird goes in.
I do a lot of projects that don't make "sense". I do them for the challenge. To learn about how things work. Some things I just do because.......brace yourself...........because they are FUN :say_what:
I say, go for it, and share the experience with us :wave:
Discussion Starter · #9 ·
What I was looking for was the ability to use two types of fuel depending on whats cheaper. For the record small
propane bottles can be refilled from 20 lb. tanks with an adapter thats availiable at Harbor Freight. A Propane powered
generator is on the horizon for me as well, mainly from the fact of poor storability of gasoline now days. I figure on doing a expendable lawn mower first before converting my expensive generator and having it not working out.
I remember in one of the vids a guy put the empty small bottles in the freezer before filling from the BBQ tank. I guess this facilitated the transfer? In either case it knocked the cost of a small bottle down.
I agree on having alternative fuel sources. When we had Superstorm Sandy, getting gas was either hard, or impossible, at times. Eventually they went to odd/even license plate numbers to ease the lines. Lots of gennies went thirsty. It was a mess. No electric, but we had propane lights and cooking, so it did help. I was loaning out camp stoves to friends/family.
The great thing about propane powered engines is you don't have to worry about the fuel system gumming up during storage.
http://uscarb.com/ and http://generatorkits.co/index.php?route=common/home sells kits to make your small engine dual fuel,
If you don't want to buy a kit, with a little studying you can figure out which regulator you need and build your own brackets and adapter.
Yup, no stabilizer, keeping the tank full, running the fuel out.
As to the regulator required, I called a supplier, and he hooked me up. I believe it is referred to as a governed regulator. Vacuum dictates flow, when the engine is shut down, propane flow ceases. Sixty bucks as I recall.
1 - 13 of 13 Posts
