1 - 2 of 2 Posts
hey, does anyone out there know if the bull gear from the transaxle can be repaired ? the hardened pin that holds the beveled gears in place sits in a slot. well the slot in worn out. i have looked at two of these gearboxes and both had the same issue. it will show up as excessive backlash on the axleshaft. i would have some pics but i can't seem to upload successfully. is the a repair? and does anyone have a pic of a good one? this is in the rearend of my qs-16. thanks for any help.
Did you download the manual? Its free in our "Manuals" section. Pictures would help us understand your problem. Try the more options tab. Check with our sponsors for the part. It may be that the slot can be oversized and an insert made. Good Luck, Rick
1 - 2 of 2 Posts
