1 - 12 of 12 Posts
Ok, so the Massey 12s (and countless others) can adjust the width of the wheel track by reversing the wheels. I know the right wheel needs to stay in its regular position so it can follow in the track of the right front wheel. But with a narrow wheelbase, a lot of the tractor's weight shifts onto the right side wheel and off the left wheel. Has anyone tried turning out only the left side wheel? It SHOULD make the tractor tilt a little less, and result in a little less weight transfer from left to right. I'm going to be running turf tires with chains, so no problems with directional tread.
It sounds like it should work . the DB plow instructions want you to do that , more the LH wheel out the way out on the axle , RH gets set for the plow .Would be enough clearance underneath if it was move out to the extreme left ?
  • Like
Reactions: HowardsMF155
Yep, extra weight on the left helps!
  • Like
Discussion Starter · #7 ·
I talked this over with my kids, especially since they are the ones driving. We also checked the displacement by turning the wheel around using a spare rim I have. We decided it might not make much difference, although I'd still like to try it one day. Mostly we concentrated on drilling holes in barbell weight plates so we could bolt them to the wheel. Put 33 lbs on the right side and 33+25 on the left. Right now, in my garden which has been worked for several years, the tractor pulls well with no chains. Got two tractors loaded, two plows, gas can, oil, a small compressor, tools, and the camera is sitting in the truck with extra batteries.
I run BOTH rear wheels in the side stance on my JD430(because they line up with the front tire and makes it easier to stay in the furrow) with 70# starter weights on both sides and usually an extra weight on each side. The last time I plowed I was having traction issues due to the ground being super hard so I added an extra 50# to the left side.
Discussion Starter · #9 ·
I had some time to re-visit this idea last weekend so I followed up, first by measuring front and rear wheels "inside tread-to-inside tread". What I found on the Massey is that the inside of the front wheels measures pretty close to 24 inches, however in the narrow position, the rear wheels are only 20 inches from inside to inside, meaning that trying to keep the front wheel firmly against the furrow wall when plowing is causing the tractor to 'crab' sideways a little.
However, by moving the wheels from one side to the other, which preserves the correct orientation of the treads, I was able to increase the inside tread measurement to nearly 24 inches, which should now mean that the tractor will sit straight in the furrow with both front and rear wheels solidly against the furrow wall.
So here the tractor sits after moving the wheels out. I was concerned that changing the tread width would impact the hitch adjustment of the plow, but nothing was noticed. I did feel that the tractor didn't pitch over at quite so steep an angle, which physics says is true, but is it detectable to human senses? The only negative Impact I noticed is that the wheel bolts were now too short to hold the weights on. However, this is balanced by the deeper well of the wheel available, which can now be filled with weight.
  • Like
Reactions: DH1
I end up with 35 more pounds on left wheel, after adding 100 pounds to each wheel. And that is just enough weight to get me traction. I only weigh 140 pounds...
Looks like you found a good work around on the issue. I have a couple of tractors that I run the front wheels a couple inches off the furrow wall, will need to look int this plan as an option.
According to the brinly manual, hitch position is determined by wheel width, but the proof is always in the results.
Oh, and I'm with Casey. I have about 27 lbs more on the uphill side... And I weigh "a little more than 140" lbs
This is something I have figured out when plowing with the FF. I haven't measured the inside track yet, but the backs are a lot closer together.
1 - 12 of 12 Posts
