1 - 13 of 13 Posts
I used the part number on the manual on this forum to order the belt that is in the right side of tractor that drives the mower deck. It was too long. I also need the belt on the left side (exhaust side) that engages when I lift the engage lever. I measured and it seems the right side is 36" and the left is 34". So im not sure if i add an inch to that or what i should do. The belt i got is a standard half inch belt. Not sure if that is correct either.
Discussion Starter · #4 ·
1711880
1711916
Or
1108584
1711916
It all depends where you look.
here are my sources.
And by the way Bolenns1000, thanks for getting those ball joints out so fast.
You also need to watch some of the aftermarket stuff,there not always cut right
Thats is also a great point, many people just go off the shoddy interchanges who sell these and have no idea they were special angles.
The ones I have been interchanging , I had to go metric special order on some of them to get them back to OEM specs
Does the model of your deck match the partslist your using?
With the early tractors many changes were made and every deck model had a different belt it seems, even if they looked the same!
Old, but not dead -- yet!
The parts diagrams shown above appear to be for two different mower decks, so there is a 50% chance of guessing at the correct belts.
The actual mower decks need to be compared to the parts diagrams to try to determine the correct model of the deck, if the Bolens tag is not found on the mower attachment.
Discussion Starter · #11 ·
Ive been looking on that bug auction site and all over the web and i cant fond a manual for 22435 02. Doing my best to be self sufficient but i only have access to the i fo available.
My mistake! .....I didn't see that you had previously posted the model of your mower deck. .....Sorry, about that !
Discussion Starter · #13 ·
No problem Bruce. Im just glad people are trying to help. I took measurements and will just figure it out. Once I have the length i will post it here so one day someone else can use the info.
1 - 13 of 13 Posts
