1 - 8 of 8 Posts
Hello everyone
Does anyone know if the tiller off a 1050 will fit a H16. shaft?
Thank 's,
Thomas
P.S. Is there a tutorial for changing out the PTO belts on a 1050?
I use one that I had on a 1050 and now on an H12. Only difference between the H series is the engine. All tube frames.
  • Like
Reactions: Tspeyfly
That tiller should bolt right up without issue
For the PTO belts you will have to remove the drive belts off the engine sheave to slide the old ones off and install the new ones.
The PTO assembly is held on by 3 bolts , loosen those to give you slack and then remove the bolts from the belt guide that should give enough wiggle room to do your belt installation
A Little Off Plumb
Here is the belt replacement and tensioning procedure from the owners manual in PDF format.
Premium Member
H12 gotta be rare! :wave: :poke:
  • Like
Reactions: Tspeyfly
Sure does. I meant G12 with a 14 hp Tech, does that make it a G14? Thanks for the heads up.
Premium Member
If it has not been replaced It would be a G14.
G12 with a bad motor. Put a 14 in I had from another project. Maybe a G13??
1 - 8 of 8 Posts
