1 - 5 of 5 Posts
Im having trouble with my mf 12g, I cant get it to go in 3 or 4 gears has anybody had this trouble before? Does anybody know if any other rear end from another garden tractor will work ? thanks
Electric Tractors
Well I would guess that the shifter forks have gone out of aline.
I you remove the 3 bolts that hold the shifter in place you can see the 2 forks and will know right away if that's the problem.
Put trany in neutral before you pull the shifter the forks should be lined up.
Electric Tractors
IamSherwood said:
Could it be that shift stopper plate?
Maybe.
I had 1 trany that went out of aline because of the detents not working good enough.
Premium Member
I think Doug nailed it for ya. Sounds like the shift forks are out of alignment.
1 - 5 of 5 Posts
