1 - 10 of 10 Posts
Recently bought a bolens 800.
Wrong size pulley on generator, so i need to remove and replace the pulley.
Would appreciate some pointers.
What? Impact knocks them off with little holding and after that isn't it only a slight tap of plastic hammer and it falls off? OR, at least not that tight at all? Heck, even later car/truck alts, had NO key and just had to tap them a bit and slid right off? I'm not familiar with this brand you speak, but most by Delco are same and shouldn't be a big issue wouldn't think? OK, I'm done, going away now!
Most times they slide right off, and the nut comes loose if they have been outside and rusted up the nut is a bit harder to get off you use the impact to shock the nut free.
1 - 10 of 10 Posts
