1 - 7 of 7 Posts
I have been working on the 8 and found both safety switches were not working. I took them apart and repaired them. Heres some photos. I first pried up three sides of the rolled over switch case to remove the back board with the terminals on it. I used a pair of small diagonal wire cutters. In the first 2 pictures you can see the dirt or bits of the back board on the contacts. It doesn't look like much but it was enough to keep the switch from making any sort of reliable contact.
Blue Wood Material property Gas Rectangle Product Electrical wiring Gas Machine Cable
I cleaned the contacts with a metal polish then rinsed them with alcohol to remove any of the polish residue which can be corrosive. I reassembled it carefully using the vice to bend the bottom flaps back down.
Wood Rectangle Gas Font Metal Blue Motor vehicle Gas Bumper Automotive exterior
In the last picture you can see the results on the meter which is in delta mode where it is measuring the resistance of the switch compared to the leads alone. It's measuring -.01 ohms which is indicating that the switch has less resistance than the leads alone. This impossibility is due to the fact that it is very hard to make precise measurements of very small resistances. Even changing the position of the leads will cause a small change. This wasn't hard to do and only took about 1/2 hour for both switches. Well worth doing as I'm not sure these switches are available new and if so will likely be pricey.
Font Measuring instrument Technology Gas Display device
Very nice work Brian! I've done that a few times...usually out of necessity out in the middle of the yard or under a time constraint! they look great and will likely serve you for many, many years to come!
Discussion Starter · #4 ·
I wanted to make sure I took some pictures for others who have bad switches but aren't sure what's involved with taking them apart. This was much easier than the PTO switch on the 314. There are no flying springs or parts when you take it apart. The hardest part is unfolding the metal bottom flaps. I have a nice blood blister on my thumb where the pliers got it.LOL
Fun With Horsepower
Yes, thanks those pics will help if I can get this one home
Motor vehicle Wheel Automotive tire Tire Vehicle
Discussion Starter · #6 ·
Boy that's a challenge! It looks worse than mine did. They are a really sturdy built little tractor. The weight is listed as 505 lbs for the electric start version including the small deck. That's probably more than most of the much larger tractors sold in the box stores these days.
Freedom is not Free. Thank those in uniform for yo
Thanks Brian, that is good info.
1 - 7 of 7 Posts
