1 - 8 of 8 Posts
Scored good today NOS
dually rims for bolens large frame
well may not be bolens but they fit my HT18
wish the guy would have had a 4th rim
3 rims with lug bolts
never had a tire on them
had original tag from a New Holland dealer
on 1 of the rims
Do you use a pair if those for each side or is that offset rim go right next to a standard wheel ?
  • Like
Reactions: 1oldbuzz
Man you are lucky!!!! Sweet find, I have been looking 4 those 4 a while....
  • Like
Reactions: 1oldbuzz
Those are an exact match the Bolens dual rims. The color is wrong though but that is simple to change. On that note seeing them in an odd color makes me wonder if they where used for other applications.
  • Like
Reactions: 1oldbuzz
Deceased
One on each side. So he actually has one extra rim.
They fit inside the standard wheels. If you look closer, you can see that 6 of the holes are oversized. That's so they can fit over the lug bolts of the inside tire.
These are also the reason that the large frames have 12 holes in the hub, as they use the 'extra' 6 holes to mount them.
You do need longer lug bolts for them.
1 - 8 of 8 Posts
