Engine has good compression, 60+ at cranking. Carb has been rebuilt and never run. Flywheel and stator produced AC voltage so probably both are good. Coil test out OK for this SS ignition. Front cover is rotted out at the bottom but has an aluminum plate to repair it. Starter/Generator has been checked at a shop and tested good. Also have an extra starter/generator. Could not get fire to the plug and am through messing with this engine. It will be replaced. If your looking for anything let me know what you want and will give you a good price as I want it out of my sight. Will list items on eBay in a week or so so don't linger.
