1 - 8 of 8 Posts
Electric Tractors
Has anyone ever put a Sears rear lift on a Massey 10 or 12 to operate the rear lift?
This way 2 attachments can be mounted to the tractor and work separately from each other.
Electric Tractors
Discussion Starter · #3 ·
I would say a newer style craftsman sleeve hitch would work better than the older style 3 point.
Got any pictures of the 2 different types?
Can you use the old style with the Massey sleeve hitch instead of the 2 lower arms?
Tractorfanatics.com
Are you referring to the manual sleeve hitch or the electric actuated one?
I mounted the manual style on a JD 212 and liked it.
The model # on the Craftsman hitch was 486 24536, and it was was 13 & 9/16" inside to inside across the mounting plates.
Electric Tractors
Discussion Starter · #7 ·
That looks like it mounts Vertical not at an angle like the older Sears GTs did.
1 - 8 of 8 Posts
