1 - 3 of 3 Posts
Was able to get out and do some grading today. The engine runs great, and doesn't smoke, but has a slow leak from the front seal when warmed up. Love the blade on this. Has down pressure, float, and the angle can be changed without getting off the seat.
Should probably upgrade the gas tank straps. ;)
The mower deck needs repair, but the tiller and snow thrower look ready to work.
Had a chat with the previous owner about the paint. He thinks baking soda caused it to fall off. He had some soda blasting done. These were sitting downwind and got what drifted out of the air.
If anyone is interested, they can own this collection for $600. located in northern Michigan and comes with a complete set of manuals.
Paul
Glad to see it running a working for you. I'm surprised that it will run with having to suck the gas upwards. But, whatever works. Too bad your across the border. I don't need the tractor, just would like to have all those attachments for mine. Good luck. Shouldn't be long till it's sold for you.
Discussion Starter · #3 ·
It has a strong fuel pump. The PO rigged this up when he couldn't find a replacement tank. Works great.
Yeah, you're not far as the crow flies, but would be a bit of a trip around the lake. Don't let that border stop you. I haul stuff back and forth all the time.
  • Like
Reactions: limebuzz
1 - 3 of 3 Posts
