1 - 2 of 2 Posts
Premium Member
Got this in a few months ago. I have used it around here some runs and drives good. The motor has been replaced with a Onan P224 everything looks good and sheet metal is straight. When the motor was changed they did not hook up the charging system instead added a car style alternator not the way I would done it. The gas tank was removed and a new one put under the seat. The front pto clutch works and there is a 60 inch deck and blade that goes with it. All four tires are close to new with little use on them. It has a rear 3 point and PTO. The PTO clutch for the rear had the wire break off it the coil so will need replaced or rewound to make work.
Asking $2500
Wheel Tire Vehicle Automotive tire Motor vehicle
Wheel Tire Vehicle Automotive tire Agricultural machinery
Motor vehicle Automotive tire Bumper Gas Automotive exterior
Wheel Tire Automotive tire Motor vehicle Vehicle
Wheel Tire Automotive tire Vehicle Motor vehicle
Tire Wheel Vehicle Automotive tire Motor vehicle
Motor vehicle Wood Asphalt Brick Gas
1 - 2 of 2 Posts
